Creates a pre-defined set for use in RADIUS Change of Authorization (CoA) and Extreme Dynamic ACL via Radius VSA 232.
| access-list | Specifies access-list features. |
| action-set | Defines a set of actions that can be applied to multiple sets of match conditions. |
| set-id | Identifies the global action-set ID (range 1–63). |
| drop | Specifies dropping any packets that match this rule. |
| forward | Specifies forwarding any packets that match this rule. |
| cos | Specifies setting Class of Service (CoS). |
| cos | Specifies the CoS value: 0–255, or -1 for no CoS, or CoS with no forwarding behavior to remove forwarding behavior. |
| mirror-destination | Specifies setting a mirror destination control index. |
| control_index | Specifies setting the mirror destination control index (1–4). |
| syslog | Specifies Syslog logging using event Policy.LogRuleHit when first rule use occurs. |
N/A.
You can view your configurations made with this command using the show policy access-list action-set {set_id} command.
The following example creates an action set "1" with CoS level of 3 and Syslog behavior:
# create policy access-list action-set 1 cos 3 syslog
This command will be accepted only if the mode is set to access-list and slices must be shared by entering the command configure policy slices shared 2 and configure policy slices tci-overwrite 2.
This command was first available in ExtremeXOS 30.5.
